These page is not indexed by Google, and it gets blocked while accessing it via API.
Here is the link: https://www.bizappln.com/blog/ghost/api/content/posts/
Kindly check from your side and resolve this issue ASAP!
Hope to hear back from you.
Thanks,
Bala.
mjw
2
The 403 means the request is disallowed by robots.txt. This is correct behaviour since your (and every) robots.txt has Disallow: /ghost/.
I didn’t add Disallow: /ghost/ in our robots file. What do you recommend me to do?
mjw
4
You don’t need to do anything. This is correct behaviour, as you don’t want robots crawling the /ghost/ folder.
So it won’t affect the indexing of the blog posts,right?
mjw
6
No. Your robots.txt is instructing search engines to crawl https://www.bizappln.com/blog/sitemap.xml.
