Blog post emails work, magic link and 2FA code emails don't
I had to move Ghost to a new server today, and upgraded to the latest Ghost 6 (6.39.0) at the same time. I imported my posts, manually re-added comments (these don’t appear to be included in the backup). Next I configured Mailgun. The blog is working for the most part.
When writing a post I can successfully email myself a preview of the post. Unfortunately, user signups, sending a magic link to login, and sending administrator 2FA codes is failing.
Comparing my old and new server, there is no SMTP configuration in config.production.json in either case. My old server was running Ghost 5.
When attempting to send a magic link for sign in I receive the error “Failed to log in, please try again”.
Running ghost log shows me:
[2026-05-20 16:40:16] ERROR "POST /members/api/send-magic-link/" 500 117ms
CODE: ESOCKET
MESSAGE: Failed to send email. Reason: connect ECONNREFUSED ::1:587.
level: normal
"Please see https://ghost.org/docs/config/#mail for instructions on configuring email."
Error: connect ECONNREFUSED ::1:587
    at createMailError (/var/www/jonsdocs/www/versions/6.39.0/core/server/services/mail/ghost-mailer.js:90:12)
    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1637:16)
I am unclear why sending magic links and 2FA codes is not being sent via the configured (and working) Mailgun configuration. There is no SMTP server running on my host, nor was there on the previous host.
Could anybody point me in the correct direction please?
Platform information
  • Ubuntu 24.04
  • Mysql Ver 8.0.45-0ubuntu0.24.04.1 for Linux on x86_64 ((Ubuntu))
  • Node 22
Ghost doctor output
    OS: Ubuntu, v24.04.4 LTS
    Node Version: v22.22.2
    Ghost Version: 6.39.0
    Ghost-CLI Version: 1.29.3
    Environment: production
    Command: 'ghost doctor'
✔ Checking system Node.js version - found v22.22.2
✔ Checking logged in user
+ sudo systemctl is-active ghost_blog-jonsdocs-org-uk
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v22.22.2
Other posts
I’m aware of Failing to setup SMTP from 2023 but that does have configuration in the JSON file. As my previous (working) instance did not have that configuration I’ve not made any changes to the JSON configuration at this stage.
Many thanks in advance.
Best guess: Your previous server /did/ accept emails coming from Ghost. Your new one doesn’t.
So… you need to configure transactional email. You can configure it to go out via mailgun’s SMTP service, or API service, or one of multiple other providers (for transactional email – newsletters are locked on mailgun), but you need to configure something. :)
Thanks @Cathy_Sarisky, and sorry it’s taken so long for me to look back at this. I’ve gone through and configured transactional email in config.production.json this morning and that’s all working again.
I think I must have configured a local SMTP server, as you say. I couldn’t find evidence of that when I checked before, but I was up against a tight deadline and not thinking straight.
For those that find this post later, I used the configuration documentation here: Configuration - Ghost Developer Docs .
