After you upgraded Docker image to 4.4.0 I can’t manage to fix the setup. I tried to follow this suggestion but I cant perform ghost update since ghost container is continuously crashing…
Steps I tried:
- exec into DB container and appended:
init-connect='SET default_collation_for_utf8mb4=utf8mb4_general_ci'
into/etc/mysql/conf.d/docker.cnf:[mysqld] skip-host-cache skip-name-resolve init-connect=SET default_collation_for_utf8mb4=utf8mb4_general_ci - restarted the db:
service mariadb restart:service mariadb restart * Stopping MariaDB database server mariadbd * Starting MariaDB database server mariadbd - cant exec into
ghostcontainer since is continuously crashing:ghost.522 | [2021-05-08 10:58:42] ERROR alter table `members_products` add constraint `members_products_member_id_foreign` foreign key (`member_id`) references `members` (`id`) on delete CASCADE - ER_CANT_CREATE_TABLE: Can't create table `ghost`.`members_products` (errno: 150 "Foreign key constraint is incorrectly formed") ghost.522 | ghost.522 | alter table `members_products` add constraint `members_products_member_id_foreign` foreign key (`member_id`) references `members` (`id`) on delete CASCADE - ER_CANT_CREATE_TABLE: Can't create table `ghost`.`members_products` (errno: 150 "Foreign key constraint is incorrectly formed") ghost.522 | ghost.522 | {"config":{"transaction":false},"name":"02-add-members-products-table.js"} ghost.522 | "Error occurred while executing the following migration: 02-add-members-products-table.js" ghost.522 | ghost.522 | Error ID: ghost.522 | 300 ghost.522 | ghost.522 | Error Code: ghost.522 | ER_CANT_CREATE_TABLE ghost.522 | ghost.522 | ---------------------------------------- ghost.522 | ghost.522 | MigrationScriptError: alter table `members_products` add constraint `members_products_member_id_foreign` foreign key (`member_id`) references `members` (`id`) on delete CASCADE - ER_CANT_CREATE_TABLE: Can't create table `ghost`.`members_products` (errno: 150 "Foreign key constraint is incorrectly formed") ghost.522 | at MigrationScriptError.KnexMigrateError (/var/lib/ghost/versions/4.4.0/node_modules/knex-migrator/lib/errors.js:7:26) ghost.522 | at new MigrationScriptError (/var/lib/ghost/versions/4.4.0/node_modules/knex-migrator/lib/errors.js:25:26) ghost.522 | at /var/lib/ghost/versions/4.4.0/node_modules/knex-migrator/lib/index.js:1055:19 ghost.522 | at processTicksAndRejections (internal/process/task_queues.js:93:5) ghost.522 | ghost.522 | Error: ER_CANT_CREATE_TABLE: Can't create table `ghost`.`members_products` (errno: 150 "Foreign key constraint is incorrectly formed") ghost.522 | at Query.Sequence._packetToError (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/sequences/Sequence.js:47:14) ghost.522 | at Query.ErrorPacket (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/sequences/Query.js:79:18) ghost.522 | at Protocol._parsePacket (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/Protocol.js:291:23) ghost.522 | at Parser._parsePacket (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/Parser.js:433:10) ghost.522 | at Parser.write (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/Parser.js:43:10) ghost.522 | at Protocol.write (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/Protocol.js:38:16) ghost.522 | at Socket.<anonymous> (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/Connection.js:88:28) ghost.522 | at Socket.<anonymous> (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/Connection.js:526:10) ghost.522 | at Socket.emit (events.js:315:20) ghost.522 | at addChunk (internal/streams/readable.js:309:12) ghost.522 | at readableAddChunk (internal/streams/readable.js:284:9) ghost.522 | at Socket.Readable.push (internal/streams/readable.js:223:10) ghost.522 | at TCP.onStreamRead (internal/stream_base_commons.js:188:23) ghost.522 | -------------------- ghost.522 | at Protocol._enqueue (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/protocol/Protocol.js:144:48) ghost.522 | at Connection.query (/var/lib/ghost/versions/4.4.0/node_modules/mysql/lib/Connection.js:198:25) ghost.522 | at /var/lib/ghost/versions/4.4.0/node_modules/knex/lib/dialects/mysql/index.js:134:18 ghost.522 | at new Promise (<anonymous>) ghost.522 | at Client_MySQL._query (/var/lib/ghost/versions/4.4.0/node_modules/knex/lib/dialects/mysql/index.js:128:12) ghost.522 | at Client_MySQL.query (/var/lib/ghost/versions/4.4.0/node_modules/knex/lib/client.js:168:17) ghost.522 | at Runner.query (/var/lib/ghost/versions/4.4.0/node_modules/knex/lib/runner.js:151:36) ghost.522 | at Runner.queryArray (/var/lib/ghost/versions/4.4.0/node_modules/knex/lib/runner.js:248:31) ghost.522 | at processTicksAndRejections (internal/process/task_queues.js:93:5) ghost.522 | at async /var/lib/ghost/versions/4.4.0/node_modules/knex/lib/runner.js:277:18 ghost.522 | at async Object.up (/var/lib/ghost/versions/4.4.0/core/server/data/migrations/utils.js:239:13)
I am offline for more than a week now… Can somebody suggest how this can be put back to normal using docker setup please?
Thanks, Michal
