Following the instructions on installing from source
it says:
But running it on a new fresh install gets a bunch of errors:
Running "shell:master" (shell) task
Pulling down the latest master from upstream
Synchronizing submodule url for 'content/themes/casper'
Synchronizing submodule url for 'core/client'
Already on 'master'
Your branch is up to date with 'upstream/master'.
From github.com:TryGhost/Ghost
* branch master -> FETCH_HEAD
Already up to date.
yarn install v1.15.2
[1/5] Validating package.json...
warning ghost@2.23.1: The engine "cli" appears to be invalid.
[2/5] Resolving packages...
success Already up-to-date.
$ cpy node_modules/@tryghost/members-theme-bindings/build/members-theme-bindings.js core/server/public/
Done in 0.63s.
Entering 'content/themes/casper'
Already on 'master'
Your branch is up to date with 'origin/master'.
fatal: 'upstream' does not appear to be a git repository
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
fatal: run_command returned non-zero status for content/themes/casper
Warning: Command failed:
git submodule sync
git submodule update
if ! git diff --exit-code --quiet --ignore-submodules=untracked; then
echo "Working directory is not clean, do you have uncommited changes? Please commit, stash or discard changes to continue."
exit 1
fi
git checkout master
git pull upstream master
yarn
git submodule foreach "
git checkout master && git pull upstream master
Already on 'master'
Already on 'master'
Use --force to continue.
Aborted due to warnings.
Anyone has ideas on why is that?
