Warning " > bookshelf@0.14.2" has incorrect peer dependency "knex@>=0.6.10 <0.15.0"
Hi team,
I don’t think I was able to find an answer to my question, so please excuse me if this is a duplicate.
Tried upgrading my ghost (it’s currently 3.0.2) to the latest, i.e. 3.0.3, but received the error below.
Happy to attach full diagnostic log if need be, however am hoping someone knows how to deal with it?
Thanks in advance!
ghost-mgr@ghost:/var/www/ghost$ ghost update
  • sudo systemctl is-active ghost_stig-dlugosz-eu
    :heavy_check_mark: Checking system Node.js version
    :heavy_check_mark: Ensuring user is not logged in as ghost user
    :heavy_check_mark: Checking if logged in user is directory owner
    :heavy_check_mark: Checking folder permissions
    :heavy_check_mark: Checking file permissions
    :heavy_check_mark: Checking content folder ownership
    :heavy_check_mark: Checking for available migrations
    :heavy_check_mark: Checking for latest Ghost version
    :heavy_multiplication_x: Downloading and updating Ghost to v3.0.3
    A ProcessError occurred.
warning ghost@3.0.3: The engine “cli” appears to be invalid.
warning " > bookshelf@0.14.2" has incorrect peer dependency “knex@>=0.6.10 <0.15.0”.
yarn install v1.19.1
[1/5] Validating package.json…
[2/5] Resolving packages…
[3/5] Fetching packages…
[4/5] Linking dependencies…
[5/5] Building fresh packages…
OS: Ubuntu, v16.04.6 LTS
Node Version: v10.17.0
Ghost Version: 3.0.2
Ghost-CLI Version: 1.13.1
Environment: production
Command: ‘ghost update’
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2019-11-21T07_22_41_882Z.log
ghost-mgr@ghost:/var/www/ghost$ ghost doctor
:heavy_check_mark: Checking logged in user
:heavy_check_mark: Checking operating system compatibility
:heavy_check_mark: Checking for a MySQL installation
    Instance is currently running
    :information_source: Validating config [skipped]
    :heavy_check_mark: Checking binary dependencies
Hey! Looks like that same error has been reported on the Ghost CLI GitHub repo, you might be better off following the conversation over there:
Thanks, David, appreciate it. Had a quick peek, no definite answer over there I could see so far, but I’ll keep monitoring. In the meantime if there’s anyone here who experienced similar issue I’m all ears. Cheers.
Experiencing the same error. @stiggy - were you able to find a fix?
Nope, sorry. Seems as if our two instances are somewhat isolated, so far, so there isn’t much drive to find a solution and I’m not that tech savvy to be able to do a little more digging on my own, unfortunately, unless someone points me in the right direction… :slight_smile:
I think I figured it out. Try running these -
First -
sudo npm install -g ghost-cli@latest
Next -
sudo npm install -g npm
The Ghost update went smoothly after that.
Holy crap, that easy, huh. You’re a legend, thanks much, yes it works, yay! :slight_smile:
