I’m new to Ghost, but using it seems to be relatively easy. However, when I go to Settings -> Code Injection, the text box for the header injection seems to be disabled, although I can modify the footer just fine.
Any idea why this is the case? Is it because I’m on a trial?
There was an intermittent bug in with CodeMirror fields occasionally not showing up for a small number of users in the last week on certain network connections. A fix was released in 2.14.1:
You can run ghost update to get to the latest version
I’m new to this, but I am not self-hosting, this is happening to me with ghost(pro), does your solution still apply? If so I’m not sure how to implement it.
I’m not using a Mac, there is probably an old version of Safari out there, but it seems to be an issue many folks would encounter.
It would sure be nice if it was. Anyone out there that it’s working for? I tracked down Safari from 2012 with high hopes, but it doesn’t seem to even be able to render the admin login page.
