Casper night mode not working
Hi there,
I read that the default Casper theme automatically supports dark mode. However it always stays in light mode.
All other pages change to dark mode as expected, when my MBP changes.
I use Casper Version 4.1.0 on Ghost 4.10.2.
Tested with Brave and Safari
Anyone any idea?
Thanks in advance!
Tom
Found this thread How to enable dark mode in Casper 3.0? where @DavidDarnes mentions that it should work automatically.
Just to make sure, I am talking about the front end, not the manual switch of the admin backend.
Edit:
Now I am super confused.
I tried it with https://demo.ghost.io/ just as @DavidDarnes showed in his post. But it doesnt work as well for me.
Screen Recording 2021-08-03 at 19.13.09
Looks like the dark mode option got shifted into a theme setting. I assume this was due to people like yourself wanting more control of it. Follow these directions and you should be good to go:
Thanks for the hint. So if I understand it correctly there is no automatic choice based on the operating, but only fixed settings via CSS injection?
I seriously have no idea if this is beautiful JS code, but it seems to work :smile:
<script>
const prefersDarkScheme = window.matchMedia("(prefers-color-scheme: dark)");
if (prefersDarkScheme.matches) {
  document.documentElement.classList.add('dark-mode');
</script>
Source: A Complete Guide to Dark Mode on the Web | CSS-Tricks - CSS-Tricks
Unfortunately it doesnt work as smoothly as in your video. This needs a manual refresh of the page.
Screen Recording 2021-08-03 at 20.31.14
Looks good! Nice job, not sure why it doesn’t completely change however that shouldn’t be a problem as people will just turn up to your site with their preferred mode already set :blush:
Since the toggle is a JS based solution, you also have to track the prefers-color-scheme media query! Here’s an adapted version of what I use:
const handleColorSchemePreferenceChange = event => {
    document.body.classList.toggle('dark-mode', event.matches);
const systemThemeMatch = window.matchMedia('(prefers-color-scheme: dark)');
systemThemeMatch.addEventListener('change', handleColorSchemePreferenceChange);
// Set theme for first users. Since `systemThemeMatch` and `event` both have the matches property, we can reuse the preference change function
handleColorSchemePreferenceChange(systemThemeMatch);
Aha! Well TIL, thanks @vikaspotluri123
Thanks for the hint @vikaspotluri123.
I adapted your code, however now it no longer works on my site.
Any idea what that would be?
<script>
</script>
I think document.body.classList should be document.documentElement.classList in your code. document is the very top level element, and document.body is the one below
Right, thank you for the hint David. That did the trick.
As for my learning, do you mind to explain what @vikaspotluri123 meant with:
Originally you were checking the colour scheme on load and not actively listening to the change, hence having to reload the page. @vikaspotluri123’s code listens for the change as well as checks on load. Hope this helps!
Makes total sense :smile: Thank you both @DavidDarnes and @vikaspotluri123 for your help here!
Nice Job, what a solution :grinning: :grinning: :metal:
