I would like to make the width for my posts (and also pages) to be a bit wider.
I know it’s possible by changing it in CSS or using Code Injection. But I can’t figure it out.
I’ve included a screenshot of what I wanted to do
There’s lots of ways to do this and lots of variables. Are you able to share a URL of your site, so we can see the code?
Yes, here is the link to my site.
Thanks!
The width is being defined by the CSS class .col-lg-6. You could increase the width by increasing the 50% below to something higher and adding it to your Site Header under Settings > Code Injection. Because this class could be used on other parts of your site, you’ll need to see if it messes any other pages up.
<style>
@media (min-width: 992px) {
.col-lg-6 {
flex: 0 0 50% !important;
max-width: 50% !important;
</style>
Here it is set to 85%, for example:
I can tell that the CSS isn’t being applied.
I looked over my CSS and noticed thatI left out a bracket. Whoops! I’ve fixed it, so please make sure it matches what you have in your code injection. If it’s still not working, can you share a screen shot of your code injection page?
It’s working now! Thank you, Ryan!
@TheRoyalFig Can you help me solve the problem below?
