Hi, I’m looking for a way to display some post cards (Source Theme), depending on if the user selected a certain category in a dropdown menu (sidebar) like the one in the image below.
Please, ignore the placeholder text of post cards hah.
Two main ways to do this:
Option 1 makes one big database request on the first page load and then will be super fast, but likely makes the most sense for a small number of categories, so that if you get the top 50 posts, you’re likely to get enough to display for any given category.
Option 2 makes the most sense if you have a ton of different tags, and don’t want to load a bunch of unrequested content. However it’ll feel a little slower, since you’re going to have to ask the server for the content when the user chooses a category, instead of having it all loaded but hidden.
If all of that sounds like way more coding than you had in mind, I think @brightthemes 's Rinne theme has some category-ish behavior: Rinne — Resources & Directory Ghost Theme | Bright Themes
