Hello folks, I’m following along with a guide on setting up Ghost on my own VPS, using docker-compose to setup most of the pieces.
For reference, this is the guide: How to Install Ghost CMS with Docker on Ubuntu 18.04 | Linode I realize it’s for Ubuntu 18 but I’m not sure if that matters in this case. If it does I’d appreciate that knowledge!
What version of Ghost are you using? Latest tag from Ghost docker image
What configuration? docker-compose on Ubuntu 16.04.6
I’ve omitted some output from the MySQL container but I can add them if it’s helpful. It seems to start and stay up just fine. The Ghost container is crashing.
terminal output in here
Starting ghost_db_1 ... done
Recreating ghost_ghost_1 ... done
Attaching to ghost_db_1, ghost_ghost_1
db_1 | 2019-06-17T01:12:39.921457Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
db_1 | 2019-06-17T01:12:39.926905Z 0 [Note] mysqld (mysqld 5.7.26) starting as process 1 ...
db_1 | 2019-06-17T01:12:40.180142Z 0 [Note] mysqld: ready for connections.
db_1 | Version: '5.7.26' socket: '/var/run/mysqld/mysqld.sock' port: 3306 MySQL Community Server (GPL)
ghost_1 | [2019-06-17 01:12:41] ERROR ER_HOST_NOT_PRIVILEGED: Host '172.21.0.3' is not allowed to connect to this MySQL server
ghost_1 |
ghost_1 | ER_HOST_NOT_PRIVILEGED: Host '172.21.0.3' is not allowed to connect to this MySQL server
ghost_1 |
ghost_1 | "Unknown database error"
ghost_1 |
ghost_1 | Error ID:
ghost_1 | 500
ghost_1 |
ghost_1 | Error Code:
ghost_1 |
ghost_1 | ----------------------------------------
ghost_1 |
ghost_1 | DatabaseError: ER_HOST_NOT_PRIVILEGED: Host '172.21.0.3' is not allowed to connect to this MySQL server
ghost_1 | at DatabaseError.KnexMigrateError (/var/lib/ghost/versions/2.23.4/node_modules/knex-migrator/lib/errors.js:7:26)
ghost_1 | at new DatabaseError (/var/lib/ghost/versions/2.23.4/node_modules/knex-migrator/lib/errors.js:56:26)
ghost_1 | at connection.raw.catch (/var/lib/ghost/versions/2.23.4/node_modules/knex-migrator/lib/database.js:40:19)
ghost_1 | at tryCatcher (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/util.js:16:23)
ghost_1 | at Promise._settlePromiseFromHandler (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/promise.js:512:31)
ghost_1 | at Promise._settlePromise (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/promise.js:569:18)
ghost_1 | at Promise._settlePromise0 (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/promise.js:614:10)
ghost_1 | at Promise._settlePromises (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/promise.js:690:18)
ghost_1 | at _drainQueueStep (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/async.js:138:12)
ghost_1 | at _drainQueue (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/async.js:131:9)
ghost_1 | at Async._drainQueues (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/async.js:147:5)
ghost_1 | at Immediate.Async.drainQueues [as _onImmediate] (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/async.js:17:14)
ghost_1 | at runCallback (timers.js:705:18)
ghost_1 | at tryOnImmediate (timers.js:676:5)
ghost_1 | at processImmediate (timers.js:658:5)
ghost_1 |
ghost_1 | Error: ER_HOST_NOT_PRIVILEGED: Host '172.21.0.3' is not allowed to connect to this MySQL server
ghost_1 | at Handshake.Sequence._packetToError (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/sequences/Sequence.js:47:14)
ghost_1 | at Handshake.ErrorPacket (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/sequences/Handshake.js:124:18)
ghost_1 | at Protocol._parsePacket (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/Protocol.js:278:23)
ghost_1 | at Parser.write (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/Parser.js:76:12)
ghost_1 | at Protocol.write (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/Protocol.js:38:16)
ghost_1 | at Socket.<anonymous> (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/Connection.js:91:28)
ghost_1 | at Socket.<anonymous> (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/Connection.js:502:10)
ghost_1 | at Socket.emit (events.js:198:13)
ghost_1 | at addChunk (_stream_readable.js:288:12)
ghost_1 | at readableAddChunk (_stream_readable.js:269:11)
ghost_1 | at Socket.Readable.push (_stream_readable.js:224:10)
ghost_1 | at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
ghost_1 | at Protocol._enqueue (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/Protocol.js:144:48)
ghost_1 | at Protocol.handshake (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/protocol/Protocol.js:51:23)
ghost_1 | at Connection.connect (/var/lib/ghost/versions/2.23.4/node_modules/mysql/lib/Connection.js:118:18)
ghost_1 | at _bluebird.default (/var/lib/ghost/versions/2.23.4/node_modules/knex-migrator/node_modules/knex/lib/dialects/mysql/index.js:82:18)
ghost_1 | at Promise._execute (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/debuggability.js:313:9)
ghost_1 | at Promise._resolveFromExecutor (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/promise.js:483:18)
ghost_1 | at new Promise (/var/lib/ghost/versions/2.23.4/node_modules/bluebird/js/release/promise.js:79:10)
ghost_1 | at Client_MySQL.acquireRawConnection (/var/lib/ghost/versions/2.23.4/node_modules/knex-migrator/node_modules/knex/lib/dialects/mysql/index.js:77:12)
ghost_1 | at create (/var/lib/ghost/versions/2.23.4/node_modules/knex-migrator/node_modules/knex/lib/client.js:282:21)
ghost_1 | at tryPromise (/var/lib/ghost/versions/2.23.4/node_modules/tarn/lib/Pool.js:366:22)
ghost_1 | at tryPromise (/var/lib/ghost/versions/2.23.4/node_modules/tarn/lib/utils.js:57:20)
ghost_1 | at Promise (/var/lib/ghost/versions/2.23.4/node_modules/tarn/lib/Pool.js:366:5)
ghost_1 | at callbackOrPromise (/var/lib/ghost/versions/2.23.4/node_modules/tarn/lib/Pool.js:357:10)
ghost_1 |
I’m using this docker-compose file to setup the system.
version: '3'
services:
ghost:
image: ghost:latest
restart: always
depends_on:
- db
environment:
url: https://blog.example.net
database__client: mysql
database__connection__user: root
database__connection__password: BIGPASSWORD
volumes:
- /opt/ghost_content:/var/lib/ghost/content
db:
image: mysql:5.7
restart: always
environment:
MYSQL_ROOT_PASSWORD: BIGPASSWORD
volumes:
- /opt/ghost_mysql:/var/lib/mysql
I’m omitting the nginx part of the guide since I’m running that directly myself. I’d hoped to proxy a connection to the ghost container myself. Suffice to say I’m not even that far as my containers aren’t working yet.
Does this check out? I’ve looked and seen people running commands to ALTER the root user of the MySQL db to have other/all permissions. This didn’t seem like something I could do easily here, since if the container restarts wouldn’t I need to make the alter every time? I’m not sure what 172.21.0.3 refers to, maybe the networking setup by docker?
