Hi all,
I’m using the contentAPI within After.js, and on SSR it throws
ReferenceError: XMLHttpRequest is not defined
at dispatchXhrRequest (/node_modules/@tryghost/content-api/es/content-api.js:2268:1)
at new Promise (<anonymous>)
at xhrAdapter (/build/webpack:/node_modules/@tryghost/content-api/es/content-api.js:2260:1)
at dispatchRequest (/build/webpack:/node_modules/@tryghost/content-api/es/content-api.js:2594:1)
EDIT: Fixed! Just do this in the file that does the SSR:
import { XMLHttpRequest } from 'xmlhttprequest-ssl';
global.XMLHttpRequest = XMLHttpRequest;
