Currently, when using Markdown, Ghost creates ‘footnotes’ that are actually section endnotes, with each Markdown card counting as a ‘section’ — this is not exactly ideal.
This issue has come up a number of times on this forum (see, e.g., this thread from 2019).
Instead of simply making a feature request, I have gone ahead and created a script that will do this automatically for anyone who would like to have (more) functional footnotes in Ghost when using Markdown.
Here is the code:
$(document).ready(function () {
// Check if the body element has the class 'tag-scripting-footnotes-renumber'
if ($('body').hasClass('tag-scripting-footnotes-renumber')) {
// Initialize variables to keep track of footnote counts
var footnoteCount = 0;
var referenceCount = 0;
// Create and append the endnotes div if it doesn't exist
if ($('div.endnotes').length === 0) {
var endnotesDiv = $('<div class="endnotes"></div>');
$('div.post-content').append(endnotesDiv);
// Create an ordered list for footnotes
var olFootnotes = $('<ol class="footnotes-list"></ol>');
// Iterate through each footnote reference and renumber them
$('sup.footnote-ref a').each(function () {
// Increment the footnote count
footnoteCount++;
// Generate the IDs and HREFs for the footnote and its reference
var footnoteId = 'fn' + footnoteCount;
var footnoteRefId = 'fnref' + footnoteCount;
// Update the ID, HREF, and content for the footnote reference
$(this).attr('id', footnoteRefId).attr('href', '#' + footnoteId).text('[' + footnoteCount + ']');
// Iterate through each footnote and move it to the endnotes div
$('section.footnotes').each(function () {
var section = $(this);
// Iterate through the footnotes in this section
section.find('ol.footnotes-list li.footnote-item').each(function () {
// Increment the reference count for the back references
referenceCount++;
// Generate the IDs for the footnote and its back reference
var footnoteId = 'fn' + referenceCount;
var backReferenceId = 'fnref' + referenceCount;
// Update the ID for the footnote
$(this).attr('id', footnoteId);
// Create a back reference element
var backReference = $('<a class="footnote-backref" href="#' + backReferenceId + '">↩</a>');
// Remove any existing back references within the p element
$(this).find('p a.footnote-backref').remove();
// Append the back reference to the footnote item
$(this).find('p').append(backReference);
// Append the footnote to the ordered list
olFootnotes.append($(this).detach());
// Append the ordered list of footnotes to the endnotes div
$('div.endnotes').append($('<section class="footnotes"></section>').append(olFootnotes));
I have a short post about this script on my site, but the essence of what it does is quite simple:
It renumbers footnotes across Markdown cards, merges them into a single div, and then ensures all the links work.
I do most of my writing in Markdown, and I do like segmenting longer articles using multiple cards, but I was decidedly not a fan of the mid-article ‘footnotes’ that resulted from this. Until a more extensive footnote system is integrated into Ghost, this seems like a good workaround.
