Convert ghost posts to .pdf or .doc on publish
I want to convert my ghost posts to .pdf and .doc as soon as they are published. Is there any plugin available for that?
Using Zapier you could try creating a zap for the “Post Published” trigger which uses Google Cloud Print to convert the post’s html to a pdf.
https://zapier.com/apps/google-cloud-print/integrations
Google Cloud Print is discontinued since December 2020. It would be great to be able to do this. Any tips would be appreciated.
Install Print Friendly. It won’t automatically convert them, but it’s a great feature to add to your site so your users can print, PDF, or email your articles. And, it produces a clean PDF with the ability to delete certain elements if you don’t need them. Well worth the small amount of money it costs.
Hi Bruce, I know this is from over a year ago, but wondering how did you install Print Friendly? I’m looking for a plugin for users to convert a post to PDF and can’t find any other solution. If you’re able to help, thanks in advance! :smiling_face:
Basically, you sign up with PrintFriendly first. Then, you get the line of code from them, and you add it to post.hbs where you want it to show up. I have mine right below the {content} helper.
I’ve had it installed for so long that I had to be back and look. I thought there was some code injection as well, but there isn’t.
Excellent tool.
