The ghost process uses all CPU resources and the blog becomes inaccessible. No idea why this is happening, the fix is to fully restart the server itself. Troubleshooting tips would be appreciated, however, this seems like a bug to me.
Details:
URL: blog.bcyouthcouncil.ca
Version: 3.33.0
Node Version: 10.22.0
Browser/OS: Ubuntu 18.04.5 LTS
Database: MySQL
inoryum
September 21, 2020, 2:46am
2
It could be for various reasons… first try to identify why it’s happening in your server.
You can check what process consuming the CPU or RAM by typing below command on the terminal
htop
& Then try to fix that & also the node 12 is recommended for the latest ghost
I’ve updated NodeJS to v12, hopefully that helps. It’s the ghost process itself consuming all of the CPU.
inoryum
September 22, 2020, 1:20am
4
Hope so too ! if not then I will need to check the detail log of the server why ghost process using that more resources
Thanks
Yeah, still not working. What should I do?
inoryum
September 22, 2020, 5:25pm
6
Aiden_Mitchell:
Any other sites or app installed on that server?
inoryum
September 22, 2020, 6:27pm
8
Can you send the syslog here . The access log & the ghost log
