what’s the code for this post display
I’m assuming this is Dawn?
You can see the code here - it’s in the loop.hbs file:
Yes but how do you get the styling when I do it it doesen’t come out right
You have to grab the CSS for the classes shown in loop.hbs.
I think they are here:
But again, don’t expect it to work if you are just copying whole files from one theme into another.
You need to look closely at the code and be careful about what you are copying, because the other theme you are pasting into might use the same CSS classes - in which case there will be conflicts.
Hope this helps.
did that and checked for conflicts link to the site here
