I am very new to ghost. I would like to create a custom theme for ghost stories. Every time I change the theme, I am zipping it uploading it to local environment to see if things are ok. Is there a way where I can do this on the fly, like when I make a change in theme files, I can just refresh the browser and see the changes I’ve made?
Thanks.
This page should have almost everything you’re looking for:
Thanks for the reply. I was running it in production mode, wasn’t able to edit the theme. Good to know that there is a local dev env. Thanks.
Yes for the development pahse you should install ghost in your local machine and they you may edit the files easily. :)
