Creating Posts via API
When creating a post via the API, is it poss to use:
  • Markdown
  • Create bookmarks
    Or do you have to HTTP POST 100% HTML?
Also is there any API calls to perform the bookmark generation. i.e if I do have to submit 100% HTML, are there any helpers to assist.
Thanks,
It’s possible to use markdown if you wrap it in a card.
