Run on as default pagination template. First page - Ok, second page - Ok.
Create custom pagination.hbs like default
Run on custom pagination.hbs. First page - Ok, second page - not ok (blank #get)
In my understanding, the work of the pagination element based on the base component in the get helper should not work.
If a pagination component based on a base pagination.hbs file works in the get helper, but a custom pagination.hbs file does not work in the get helper. I believe that this is a bug, or a feature of the work not described in the documentation.
Maybe someone can tell me why this is happening.
I couldn’t get a clear explanation from the development team…
I think the explanation you received on GitHub covered all the bases: pagination and get aren’t compatible.
I just set up a test instance with the default pagination helper and get. The pagination helper changes within the context of a get request, but it doesn’t ultimately work as it can’t ever serve the next page of results (among other things).
In this situation, you want to reach for dynamic routing.
