I’m currently setting up a website for an independent scientific bird monitoring program using the Senna theme.
As the website represents a scientific initiative rather than a conventional publication, I would like to use a custom static page, created entirely in the Ghost editor, as the homepage and move the standard magazine-style article feed to a separate /journal/ page.
Is it possible to achieve this through Ghost’s custom routing (routes.yaml) without modifying the original theme files, while retaining Senna’s native navigation, mobile experience and other theme features?
Ideally, I would like to avoid any theme modifications that might complicate future updates.
I would appreciate any guidance, particularly from those who have implemented a similar website structure in Ghost.
Yes — this is exactly what routes.yaml is for, and you should be able to do it without touching the theme files. The shape is: point / at a custom page you build in the editor, and move the post collection to /journal/ with a collection in routes.yaml. Because you are only changing routing, Senna’s navigation, mobile layout and other theme features stay as built — you are not editing templates, so theme updates stay clean too. Two things I would check: first, that /journal/ paginates the way you expect, and second, whether anything on the homepage (like a featured-post slot) assumes the feed lives at /. We run a similar split ourselves — Ghost stays the home for content, membership and email, and the front door is a static page — and the part that made it work was keeping the tool and the theme separate. I am not a developer either, so I tested it with a handful of posts before switching the live homepage. Good luck with the bird monitoring site.
Many thanks, Steven! This is exactly what I was hoping to hear. Knowing that you have successfully implemented a similar structure is particularly reassuring.
Keeping the theme untouched and retaining the native Ghost functionality are important considerations for me, especially for future updates.
I’ll follow your advice and test the routing and pagination before moving the live website to Ghost.
