What’s your URL ? blog.bastii717.dev
What version of Ghost are you using? Upgrade to 4.1.0
OS: Ubuntu, v20.04.2 LTS
Node Version: v12.21.0
Ghost Version: 4.1.0
Ghost-CLI Version: 1.16.3
Environment: production
And
How was Ghost installed and configured? Following the Docs How to install & setup Ghost on Ubuntu 16.04, 18.04, 20.04 or 22.04
What Node database are you using? MariaDB 10.5
Message: Ghost was able to start, but errored during boot with: alter table migrations_lock add primary key migrations_lock_pkey(lock_key) - ER_WRONG_NAME_FOR_INDEX: Incorrect index name ‘migrations_lock_lock_key_unique’
Upgrade from latest v3 build running the ghost update command.
Hannah
March 19, 2021, 7:53am
2
That’s an odd one, can you please connect to your database, run the following queries and share the output?
SHOW CREATE TABLE `migrations_lock`;
SELECT @@GLOBAL.sql_mode;
SELECT @@SESSION.sql_mode;
Hey there,
thanks for the quick response , see below for the results:
MariaDB [ghost_bastii717]> SHOW CREATE TABLE `migrations_lock`;
| Table | Create Table |
| migrations_lock | CREATE TABLE `migrations_lock` (
`lock_key` varchar(191) NOT NULL,
`locked` tinyint(1) DEFAULT 0,
`acquired_at` datetime DEFAULT NULL,
`released_at` datetime DEFAULT NULL,
UNIQUE KEY `migrations_lock_lock_key_unique` (`lock_key`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 |
1 row in set (0.002 sec)
MariaDB [ghost_bastii717]> SELECT @@GLOBAL.sql_mode;
| @@GLOBAL.sql_mode |
| STRICT_TRANS_TABLES,ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION |
1 row in set (0.003 sec)
MariaDB [ghost_bastii717]> SELECT @@SESSION.sql_mode;
| @@SESSION.sql_mode |
1 row in set (0.000 sec)
syx
March 20, 2021, 5:06pm
4
Also getting this, will chip in:
MariaDB [(none)]> USE blog;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
MariaDB [blog]> SHOW CREATE TABLE `migrations_lock`;
MariaDB [blog]> SELECT @@GLOBAL.sql_mode;
| @@GLOBAL.sql_mode |
MariaDB [blog]> SELECT @@SESSION.sql_mode;
MariaDB [blog]>
buarle
March 22, 2021, 8:05am
5
Same error here with DockerCE + MariaDB + Ghost.
jackma
March 22, 2021, 12:56pm
6
Got the same error when upgrading from v3.42.3 to v4.
Error ID:
dd913990-8b0d-11eb-8f67-898ec2cfea09
Error Code:
Not sure if you guys were looking for a fix or just reporting an issue but I had the same problem. From this old issue, it seems fine to delete the tables. I logged into the database and deleted the migrations and migrations_lock tables. This fixed the issue for me.
buarle
March 22, 2021, 9:35pm
8
indeed, I was looking for a solution. deleting the migrations* tables solved it as well for me!
mrios
April 7, 2021, 3:12am
9
Solved it for me too! Thanks @buarle and @tri-ler
