- What version of Ghost are you using? 2.22
- What configuration? Ghost in Docker: Docker
- What browser? Brave, Firefox, Edge, etc.
- What errors or information do you see in the console? 404 on webpage, not sure where I should be looking for console errors… or logs…
- What steps could someone else take to reproduce the issue you’re having? Create a docker-compose.yml file for ghost, docker-compose up -d, go through initial setup, and note the main ‘Author’ link displays a 404.
Here is my routes.yml file:
routes:
collections:
permalink: /{slug}/
template: index
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
I’ve filled out the bio info in my staff page, but I’m listed as a Owner, not sure if this has something to do with it? https://m.purrbox.org/2MaRz6f
That was exactly it.
