Display posts one by one
Right now I am having a blog that is built on top of Casper theme - it looks exactly like this: https://demo.ghost.io/
Right now, I want to display all posts one by one, with simple pagination (like 5 posts per page). Is that possible to do with Ghost?
The simplest thing you should do
Remove from default.hbs:
 {{#if pagination.pages}}
<script>
    // maxPages is a global variable that is needed to determine
    // if we need to load more pages for the infinitescroll, or if
    // we reached the last page already.
    var maxPages = parseInt('{{pagination.pages}}');</script>
<script src="{{asset "js/infinitescroll.js"}}"></script>
{{/if}}
change “posts_per_page” in package.json (template folder).
In index.hbs after
   {{/foreach}}
    </div>
add
        {{pagination}}
    {{/if}}
I think you can also edit pagination.hbs and use foreach for create “1, 2, 3, 4, last page”. For example
<a class="last-page" href="{{page_url pages}}">{{t "Last Page"}} <span aria-hidden="true">&rarr;</span></a>
add link to last page
