Duplicated image for different articles
I use gtmetrix to check the performance of my site.
I use the same images for different articles.
Ghost automatically duplicates images even if they are the same, for different articles.
This is the result:
Schermata%20del%202018-06-12%2013-42-10
How to solve?
Thank you
The duplication of identical images is probably going to be fixed in something like Better image/file management & optimisation - #13 by chrisalley, but until then, you need to do pruning and management yourself - for example, instead of uploading the https image every time, grab the link from an older article and use the markdown image block (![alt text](img src)) to insert it
Thank you for the info
