Hello Ghost Community,
I’m trying to create custom routes to filter posts by tags and further categorise and have a channel called “popular” for each tag. Basically show the most popular posts within a tag in a specific format.
The goal is to set up a dynamic structure where the tag slug is used to filter posts, without hardcoding any specific values.
Here’s what I’ve tried in my routes.yaml file to setup this channel:
routes:
/:slug/popular/:
controller: channel
template: popular
filter: tag:[{:slug}]
collections:
permalink: /{primary_tag}/{slug}/
template: index
taxonomies:
tag: /{slug}/
The intention is for this configuration to allow URLs like:
| URL (Channel) | Associated Tag URL |
https://www.wisdominanutshell.academy/andrew-huberman/popular |
https://www.wisdominanutshell.academy/andrew-huberman/ |
https://www.wisdominanutshell.academy/elon-musk/popular |
https://www.wisdominanutshell.academy/elon-musk/ |
https://www.wisdominanutshell.academy/steve-jobs/popular |
https://www.wisdominanutshell.academy/steve-jobs/ |
This should work across all tags, fetching all posts with a specific tag (e.g., “andrew-huberman”) and then filtering them under a “popular” channel using the given slug. I will later render them there in there with the “popular” template.
Unfortunately, this configuration doesn’t seem to be working, and it returns empty pages. I think filter does not allow this. When I hard code explicitly
/andrew-huberman/popular/:
controller: channel
template: popular
filter: tag:[andrew-huberman]
then it works. I’d like to avoid hardcoding specific values for each tag. I have 100 or more tags.
Questions:
- Is it possible to directly use the value “:slug” in the
filterproperty? - If not, what would be the best way to achieve this dynamic filtering based on the URL slug?
I appreciate any guidance on this issue. Thank you in advance for your assistance!
Best regards,
Adi
