Hi
I’ve got a couple of posts using embedded url such as AWS Basics
I’ve tried to add new posts with similar embedded URL but it is not allowing as a bookmark or embedded URL. Ghost and OS has been patch since original posts were created but I can not seem to find a way to resolve this.
Any help appreciated.
blog.myaws.rocks running ghost 4.11.0
Ghost-CLI version: 1.17.3
Ghost version: 4.11.0 (at /var/www/myaws.rocks)
Installed and configured per production install guide on ghost website.
Running on RaspberryPi Ubuntu
Ubuntu Version
Linux ubuntu 5.11.0-1015-raspi #16-Ubuntu SMP PREEMPT Wed Jul 14 11:04:58 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
ghost doctor
✔ Checking system Node.js version - found v14.17.5
✔ Checking logged in user
System checks failed with message: 'Linux version is not Ubuntu 16, 18, or 20'
For local installs we recommend using `ghost install local` instead.
? Continue anyway? Yes
System stack check skipped
ℹ Checking system compatibility [skipped]
+ sudo systemctl is-active ghost_blog-myaws-rocks
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v14.17.5
Using Chrome on Windows 10.
With a new post.
Click + sign
add bookmark
paste www.bbc.co.uk
error is “No provider found for supplied URL.”
OR
Click + sign
add other / embed
paste www.bbc.co.uk
error is “There was an error when parsing the URL.”
Chrome Console displays the same error for both option.
0: {message: "Validation error, cannot read oembed.", context: "No provider found for supplied URL.",…}
code: null
details: null
help: null
property: null
type: "ValidationError"
isting post which has links embed that display as expected (
