check this two post
My query is just about the missing header block when the default is moved to / blog that’s present in London theme home.
me tried with london theme no issue work perfect
header block are visible
@vamsi3001 are you still having trouble with this? It might be wise for you to check over everything you’ve implemented and ensure none of your code is conflicting with itself.
With regards to this:
The custom home page tutorial covers a set of solutions that others will use in a variety of ways. It might not be in priority order for you, but maybe for others ![]()
Still I couldn’t get the header section on my /blog page as it was in the London theme. It only disappeared when I moved the blog collections page from / to /blog
That’ll be because the template is no longer being used for the home page, you’ll need to remove the lines {{#is "home"}} and {{/is}} from the template, you can see them here on the original theme:
This helped and the post can be closed now.
Page you link to here is 404.
