when i set up caddy like this vid
with my ghost stack on portainer
version: '3.1'
services:
ghost:
image: ghost:latest
restart: always
ports:
- 2368:2368
environment:
# see https://ghost.org/docs/config/#configuration-options
database__client: mysql
database__connection__user: root
database__connection__password: example
# this url value is just an example, and is likely wrong for your environment!
url: https://srimuang.duckdns.org
# contrary to the default mentioned in the linked documentation, this image defaults to NODE_ENV=production (so development mode needs to be explicitly specified if desired)
#NODE_ENV: development
db:
image: mysql:latest
restart: always
environment:
MYSQL_ROOT_PASSWORD: example
when i enter my domain it show
This site can’t be reachedsrimuang.duckdns.org took too long to respond.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
when i enter IP it shows
# This site can’t provide a secure connection
**myip** sent an invalid response.
* [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
what should i do ??
