I appear to have botched an upgrade and am hoping that there is some way to salvage this installation or at worst extract the content from the database to migrate into a new installation.
I’m tempted to go through the schema of a known good installation and try to manually rebuild whatever is missing from my database, but that sounds tedious and more importantly won’t get to the bottom of why this happened in the first place. That’s important because I have broken two sites: one I tried to get from 3.38.3 to 3.42.2 and then to 4; the second (described here) I realized was dead before I got to try to upgrade to 4.
Here’s most of what the help topic template asks for:
- URL https://positronic.works/ but all you’ll see there is a 502 Bad Gateway error
- What version of Ghost It was 3.38.3 when it was running. I tried to update to 3.42.2 in preparation for an update to Ghost 4
How was Ghost installed and configured? cli
ghost install - Node version Node v12.21.0
- Database MySQL 8.0.23-0ubuntu0.20.04.1,
- OS Ubuntu 20.04.2 LTS (GNU/Linux 5.4.0-67-generic x86_64)
- Browser Safari on Mac, elinks on ubuntu
I was behind on my updates, back at 3.38.3, and got the announcement about Ghost 4. So I decided it was time to spend a little time updating. If I’d been smart I’d have done a backup first thing, but I decided to do the point upgrade to 3.42.2 first and do a backup before upgrading to Ghost 4.I thought the point update was anodyne and risk-free. I was stupid, obviously.
I started with npm install -g ghost-cli@latest as root and then perforned the update with ghost update v3 as the user the instance runs under:
positronic@electra:/srv/positronic.works$ ghost update v3
+ sudo systemctl is-active ghost_positronic-works
? Sudo Password [hidden]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking for available migrations
All up to date!
Looked good at that point but nginx was (and is) reporting 502 Bad Gateway. Attempting to access localhost:2370 directly (with elinks) resulted in Connection Refused. So I checked to see if it was in fact running:
positronic@electra:/srv/positronic.works$ ghost ls
│ Name │ Location │ Version │ Status │ URL │ Port │ Process Manager │
│ positronic-works │ /srv/positronic.works │ 3.42.2 │ running (production) │ https://positronic.works │ 2370 │ systemd │
However, I don’t see anything listening (or anything else) on port 2370:
root@electra:~# lsof -i -P -n | grep LISTEN
systemd-r 535 systemd-resolve 13u IPv4 21052 0t0 TCP 127.0.0.53:53 (LISTEN)
sshd 666 root 3u IPv4 22876 0t0 TCP *:22 (LISTEN)
sshd 666 root 4u IPv6 22878 0t0 TCP *:22 (LISTEN)
nginx 703 root 6u IPv4 23180 0t0 TCP *:443 (LISTEN)
nginx 703 root 7u IPv6 23181 0t0 TCP *:443 (LISTEN)
nginx 703 root 8u IPv4 23182 0t0 TCP *:80 (LISTEN)
nginx 703 root 9u IPv6 23183 0t0 TCP *:80 (LISTEN)
nginx 708 www-data 6u IPv4 23180 0t0 TCP *:443 (LISTEN)
nginx 708 www-data 7u IPv6 23181 0t0 TCP *:443 (LISTEN)
nginx 708 www-data 8u IPv4 23182 0t0 TCP *:80 (LISTEN)
nginx 708 www-data 9u IPv6 23183 0t0 TCP *:80 (LISTEN)
mysqld 745 mysql 32u IPv4 25223 0t0 TCP 127.0.0.1:33060 (LISTEN)
mysqld 745 mysql 51u IPv4 25230 0t0 TCP 127.0.0.1:3306 (LISTEN)
master 879 root 13u IPv4 24288 0t0 TCP *:25 (LISTEN)
master 879 root 14u IPv6 24289 0t0 TCP *:25 (LISTEN)
node 1042 ghost 27u IPv4 26209 0t0 TCP 127.0.0.1:2369 (LISTEN)
root@electra:~# lsof -i -P -n | grep 2370
root@electra:~#
(There is another site running on port 2369. There’s supposed to be one running on 2368 too but I’m trying to fix one installation at a time)
So I tried rolling back to 3.38.3 but that got me a 'No previous version found' message.
ghost run gave me an actual error message:
[2021-03-16 18:22:06] ERROR alter table `email_recipients` drop foreign key `email_recipients_email_id_foreign` - ER_CANT_DROP_FIELD_OR_KEY: Can't DROP 'email_recipients_email_id_foreign'; check that column/key exists
"OuterError: update `members` set `email_count` = (SELECT COUNT(id) FROM email_recipients WHERE email_recipients.member_id = members.id), `email_opened_count` = (SELECT COUNT(id) FROM email_recipients WHERE email_recipients.member_id = members.id AND email_recipients.opened_at IS NOT NULL) - ER_CANT_AGGREGATE_2COLLATIONS: Illegal mix of collations (utf8mb4_0900_ai_ci,IMPLICIT) and (utf8mb4_general_ci,IMPLICIT) for operation '='"
Error ID:
400
Error Code:
RollbackError: alter table `email_recipients` drop foreign key `email_recipients_email_id_foreign` - ER_CANT_DROP_FIELD_OR_KEY: Can't DROP 'email_recipients_email_id_foreign'; check that column/key exists
at RollbackError.KnexMigrateError (/srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/lib/errors.js:7:26)
at new RollbackError (/srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/lib/errors.js:31:26)
at /srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/lib/index.js:440:23
at tryCatcher (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/promise.js:547:31)
at Promise._settlePromise (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/promise.js:604:18)
at Promise._settlePromise0 (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/promise.js:649:10)
at Promise._settlePromises (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/promise.js:725:18)
at _drainQueueStep (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/async.js:93:12)
at _drainQueue (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/async.js:86:9)
at Async._drainQueues (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/async.js:102:5)
at Immediate.Async.drainQueues [as _onImmediate] (/srv/positronic.works/versions/3.42.2/node_modules/bluebird/js/release/async.js:15:14)
at processImmediate (internal/timers.js:461:21)
Error: ER_CANT_DROP_FIELD_OR_KEY: Can't DROP 'email_recipients_email_id_foreign'; check that column/key exists
at Query.Sequence._packetToError (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/sequences/Sequence.js:47:14)
at Query.ErrorPacket (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/sequences/Query.js:79:18)
at Protocol._parsePacket (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/Protocol.js:291:23)
at Parser._parsePacket (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/Parser.js:433:10)
at Parser.write (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/Parser.js:43:10)
at Protocol.write (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/Protocol.js:38:16)
at Socket.<anonymous> (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/Connection.js:88:28)
at Socket.<anonymous> (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/Connection.js:526:10)
at Socket.emit (events.js:314:20)
at Socket.EventEmitter.emit (domain.js:483:12)
at addChunk (_stream_readable.js:297:12)
at readableAddChunk (_stream_readable.js:272:9)
at Socket.Readable.push (_stream_readable.js:213:10)
at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
at Protocol._enqueue (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/protocol/Protocol.js:144:48)
at Connection.query (/srv/positronic.works/versions/3.42.2/node_modules/mysql/lib/Connection.js:198:25)
at /srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/dialects/mysql/index.js:135:18
at new Promise (<anonymous>)
at Client_MySQL._query (/srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/dialects/mysql/index.js:129:12)
at Client_MySQL.query (/srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/client.js:169:17)
at Runner.query (/srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/runner.js:151:36)
at Runner.queryArray (/srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/runner.js:248:31)
at /srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/runner.js:38:25
at /srv/positronic.works/versions/3.42.2/node_modules/knex-migrator/node_modules/knex/lib/runner.js:277:24
at processTicksAndRejections (internal/process/task_queues.js:97:5)
at async down (/srv/positronic.works/versions/3.42.2/core/server/data/migrations/versions/3.39/06-add-email-recipient-index.js:46:13)
at async Object.down (/srv/positronic.works/versions/3.42.2/core/server/data/migrations/utils.js:219:13)
So it looks to me like the upgrade process go hung up somewhere and and can’t proceed any further because the database changes that it wants to make either because it’s already been done or because it’s relying on something that should have been created but wasn’t.
Thanks for reading this far. I appear to have automatic backups for all my VPSs… except this one. One of the sites was in the beginning stages of development so I can start over from scratch. The other one has the content backed up not as recently as I’d like but it isn’t the end of the world. However, until I figure out what went wrong — specifically what I did wrong (other than not checking my backups first) I don’t dare try doing any of the other ghost site upgrades I need to do.
All suggestions are appreciated.
