- What’s your URL?
https://dursuncanpoyraz.com.tr - What version of Ghost are you using?
Ghost-CLI version: 1.15.3
Ghost version: 3.40.2 (at /var/www/ghost) - What configuration?
Nginx 1.16 , Ubuntu 18.04 - What browser?
Chrome - What errors or information do you see in the console?
Failed to load resource: the server responded with a status of 502 (Bad Gateway) - What steps could someone else take to reproduce the issue you’re having? -
dursuncan@localhost:/var/www/ghost$ ghost setup
? Enter your blog URL: https://dursuncanpoyraz.com.tr
? Enter your MySQL hostname: localhost
? Enter your MySQL username: websites
? Enter your MySQL password (skip to keep current password): [hidden]
? Enter your Ghost database name: websites
✔ Configuring Ghost
+ sudo chown -R ghost:ghost /var/www/ghost/content
✔ Setting up "ghost" system user
ℹ Setting up "ghost" mysql user [skipped]
? Do you wish to set up Nginx? Yes
+ sudo mv /tmp/ghost-local/dursuncanpoyraz.com.tr.conf /etc/nginx/sites-available/dursuncanpoyraz.com.tr.conf
+ sudo ln -sf /etc/nginx/sites-available/dursuncanpoyraz.com.tr.conf /etc/nginx/sites-enabled/dursuncanpoyraz.com.tr.conf
+ sudo nginx -s reload
✔ Setting up Nginx
? Do you wish to set up SSL? Yes
? Enter your email (For SSL Certificate) poyrazdursuncan@gmail.com
+ sudo /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --domain dursuncanpoyraz.com.tr --webroot /var/www/ghost/system/nginx-root --reloadcmd "nginx -s reload" --accountemail poyrazdursuncan@gmail.com
+ sudo openssl dhparam -dsaparam -out /etc/nginx/snippets/dhparam.pem 2048
+ sudo mv /tmp/ssl-params.conf /etc/nginx/snippets/ssl-params.conf
+ sudo mv /tmp/ghost-local/dursuncanpoyraz.com.tr-ssl.conf /etc/nginx/sites-available/dursuncanpoyraz.com.tr-ssl.conf
+ sudo ln -sf /etc/nginx/sites-available/dursuncanpoyraz.com.tr-ssl.conf /etc/nginx/sites-enabled/dursuncanpoyraz.com.tr-ssl.conf
✔ Setting up SSL
Systemd service has already been set up. Skipping Systemd setup
ℹ Setting up Systemd [skipped]
ℹ Starting Ghost [skipped]
Ghost was installed successfully! To complete setup of your publication, visit:
/ghost/
I am using Cloudflare. The links to https://dursuncanpoyraz.com.tr/ghost fails.
https://dursuncanpoyraz.com.tr:2369/ghost link is not accessible.
