Using the docs:
Did an npm install of the latest version of ghost, then did a ghost install local
Node Version: v16.14.2.
OS: Windows 10
0 verbose cli [
0 verbose cli ‘C:\Program Files\nodejs\node.exe’,
0 verbose cli ‘C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js’,
0 verbose cli ‘install’,
0 verbose cli ‘@vscode/sqlite3’,
0 verbose cli ‘–save’
0 verbose cli ]
1 info using npm@8.5.0
2 info using node@v16.14.2
3 timing npm:load:whichnode Completed in 1ms
4 timing config:load:defaults Completed in 4ms
5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 8ms
6 timing config:load:builtin Completed in 9ms
7 timing config:load:cli Completed in 5ms
8 timing config:load:env Completed in 1ms
9 timing config:load:file:c:\ghost_cli.npmrc Completed in 1ms
10 timing config:load:project Completed in 7ms
11 timing config:load:file:C:\Users\vigra.npmrc Completed in 2ms
12 timing config:load:user Completed in 3ms
13 timing config:load:file:C:\Users\vigra\AppData\Roaming\npm\etc\npmrc Completed in 0ms
14 timing config:load:global Completed in 1ms
15 timing config:load:validate Completed in 0ms
16 timing config:load:credentials Completed in 2ms
17 timing config:load:setEnvs Completed in 2ms
18 timing config:load Completed in 36ms
19 timing npm:load:configload Completed in 36ms
20 timing npm:load:setTitle Completed in 0ms
21 timing config:load:flatten Completed in 8ms
22 timing npm:load:display Completed in 11ms
23 verbose logfile C:\Users\vigra\AppData\Local\npm-cache_logs\2022-04-16T11_29_53_362Z-debug-0.log
24 timing npm:load:logFile Completed in 18ms
25 timing npm:load:timers Completed in 0ms
26 timing npm:load:configScope Completed in 0ms
27 timing npm:load Completed in 68ms
28 timing arborist:ctor Completed in 2ms
29 silly logfile start cleaning logs, removing 2 files
30 timing arborist:ctor Completed in 1ms
31 timing idealTree:init Completed in 31ms
32 timing idealTree:userRequests Completed in 6ms
33 silly idealTree buildDeps
34 silly fetch manifest @vscode/sqlite3@*
35 http fetch GET 200 https://registry.npmjs.org/@vscode%2Fsqlite3 1788ms (cache revalidated)
36 silly placeDep ROOT @vscode/sqlite3@5.0.8 OK for: want: *
37 silly fetch manifest node-addon-api@^4.2.0
38 http fetch GET 200 https://registry.npmjs.org/node-addon-api 86ms (cache revalidated)
39 timing idealTree:#root Completed in 1910ms
40 silly placeDep ROOT node-addon-api@4.3.0 OK for: @vscode/sqlite3@5.0.8 want: ^4.2.0
41 timing idealTree:node_modules/@vscode/sqlite3 Completed in 8ms
42 timing idealTree:node_modules/node-addon-api Completed in 0ms
43 timing idealTree:buildDeps Completed in 1922ms
44 timing idealTree:fixDepFlags Completed in 1ms
45 timing idealTree Completed in 1964ms
46 timing reify:loadTrees Completed in 1966ms
47 timing reify:diffTrees Completed in 4ms
48 silly reify moves {}
49 timing reify:retireShallow Completed in 1ms
50 timing reify:createSparse Completed in 9ms
51 timing reify:loadBundles Completed in 0ms
52 silly audit bulk request { ‘@vscode/sqlite3’: [ ‘5.0.8’ ], ‘node-addon-api’: [ ‘4.3.0’ ] }
53 timing reifyNode:node_modules/node-addon-api Completed in 176ms
54 timing reifyNode:node_modules/@vscode/sqlite3 Completed in 262ms
55 timing reify:unpack Completed in 263ms
56 timing reify:unretire Completed in 0ms
57 timing build:queue Completed in 4ms
58 info run @vscode/sqlite3@5.0.8 install node_modules/@vscode/sqlite3 node-gyp rebuild
59 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 845ms
60 timing auditReport:getReport Completed in 849ms
61 silly audit report {}
62 timing auditReport:init Completed in 0ms
63 timing reify:audit Completed in 851ms
64 info run @vscode/sqlite3@5.0.8 install { code: 1, signal: null }
65 timing reify:rollback:createSparse Completed in 39ms
66 timing reify:rollback:retireShallow Completed in 0ms
67 timing command:install Completed in 9706ms
68 verbose stack Error: command failed
68 verbose stack at ChildProcess. (C:\Program Files\nodejs\node_modules\npm\node_modules@npmcli\promise-spawn\index.js:64:27)
68 verbose stack at ChildProcess.emit (node:events:526:28)
68 verbose stack at maybeClose (node:internal/child_process:1092:16)
68 verbose stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
69 verbose pkgid @vscode/sqlite3@5.0.8
70 verbose cwd c:\ghost_cli
71 verbose Windows_NT 10.0.19044
72 verbose argv “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js” “install” “@vscode/sqlite3” “–save”
73 verbose node v16.14.2
74 verbose npm v8.5.0
75 error code 1
76 error path c:\ghost_cli\node_modules@vscode\sqlite3
77 error command failed
78 error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
79 error gyp info it worked if it ends with ok
79 error gyp info using node-gyp@8.4.1
79 error gyp info using node@16.14.2 | win32 | x64
79 error gyp info find Python using Python version 3.9.12 found at “C:\Users\vigra\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\python.exe”
79 error gyp info find VS using VS2017 (15.9.28307.1300) found at:
79 error gyp info find VS “C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools”
79 error gyp info find VS run with --verbose for detailed information
79 error gyp info spawn C:\Users\vigra\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\python.exe
79 error gyp info spawn args [
79 error gyp info spawn args ‘C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\gyp\gyp_main.py’,
79 error gyp info spawn args ‘binding.gyp’,
79 error gyp info spawn args ‘-f’,
79 error gyp info spawn args ‘msvs’,
79 error gyp info spawn args ‘-I’,
79 error gyp info spawn args ‘c:\ghost_cli\node_modules\@vscode\sqlite3\build\config.gypi’,
79 error gyp info spawn args ‘C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\addon.gypi’,
79 error gyp info spawn args ‘C:\Users\vigra\AppData\Local\node-gyp\Cache\16.14.2\common.gypi’,
79 error gyp info spawn args ‘-Dlibrary=shared_library’,
79 error gyp info spawn args ‘-Dvisibility=default’,
79 error gyp info spawn args ‘-Dnode_root_dir=C:\Users\vigra\AppData\Local\node-gyp\Cache\16.14.2’,
79 error gyp info spawn args ‘-Dnode_gyp_dir=C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp’,
79 error gyp info spawn args ‘-Dnode_lib_file=C:\\Users\\vigra\\AppData\\Local\\node-gyp\\Cache\\16.14.2\\<(target_arch)\\node.lib’,
79 error gyp info spawn args ‘-Dmodule_root_dir=c:\ghost_cli\node_modules\@vscode\sqlite3’,
79 error gyp info spawn args ‘-Dnode_engine=v8’,
79 error gyp info spawn args ‘–depth=.’,
79 error gyp info spawn args ‘–no-parallel’,
79 error gyp info spawn args ‘–generator-output’,
79 error gyp info spawn args ‘c:\ghost_cli\node_modules\@vscode\sqlite3\build’,
79 error gyp info spawn args ‘-Goutput_dir=.’
79 error gyp info spawn args ]
79 error gyp: C:\Users\vigra\AppData\Local\node-gyp\Cache\16.14.2\common.gypi not found (cwd: c:\ghost_cli\node_modules@vscode\sqlite3) while reading includes of binding.gyp while trying to load binding.gyp
79 error gyp ERR! configure error
79 error gyp ERR! stack Error: gyp failed with exit code: 1
79 error gyp ERR! stack at ChildProcess.onCpExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:259:16)
79 error gyp ERR! stack at ChildProcess.emit (node:events:526:28)
79 error gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
79 error gyp ERR! System Windows_NT 10.0.19044
79 error gyp ERR! command “C:\Program Files\nodejs\node.exe” “C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js” “rebuild”
79 error gyp ERR! cwd c:\ghost_cli\node_modules@vscode\sqlite3
79 error gyp ERR! node -v v16.14.2
79 error gyp ERR! node-gyp -v v8.4.1
79 error gyp ERR! not ok
80 verbose exit 1
81 timing npm Completed in 10969ms
82 verbose unfinished npm timer reify 1650108594468
83 verbose unfinished npm timer reify:build 1650108596751
84 verbose unfinished npm timer build 1650108596752
85 verbose unfinished npm timer build:deps 1650108596752
86 verbose unfinished npm timer build:run:install 1650108596757
87 verbose unfinished npm timer build:run:install:node_modules/@vscode/sqlite3 1650108596757
88 verbose code 1
I installed ghost but on the step where it tries to start ghost, I get an error telling me that vscode/sqlite3 is missing an provides me with an npm install statement. This is the error I get when I try to npm Install vscode/sqlite3^
I am frankly not even sure of exactly what can be done. If I knew this I could have probably fixed the issue.
