Error with build CSS
Hello,
Is there any other local install with could help me build new theme?
Cant build theme files.
Please provide more information. Which theme? Did you install gulp?
If you’re developing on Windows, I highly recommend installing WSL2 and using that for your Node, NPM, and Ghost install directly. Works lots better than plain windows. :)
Fixed, now it’s working :)
Just more time was needed to run dev env :)
sob., 30 gru 2023, 18:30 użytkownik Cathy Sarisky via Ghost Forum <notifications@ghost2.discoursemail.com> napisał:
Tell me is it possible to use bootstrap in theme?
No reason why you can’t do that.
