Hi All,
I’ve been using Ghost a lot recently to convert some old Wordpress sites. I was getting fairly annoyed at going through and removing a lot of the styling stuff from the Casper theme and giving it a clear out to start from scratch.
So, I’ve built a Barebones/Skeleton Theme for Ghost which can be installed to start from scratch.
Grab it on Github here.
Any feedback pop an issue on Github.
Veeeeeeeeery cool. Thanks !
Hello @JMKelley !
I’ve finally found the time to dive a little bit into your starter theme. Could you please provide the gulpfile.js that you use to developp the theme ? I’ve an error message in my terminal when trying to run Yarn.
That would be very much helpful
Thanks !
Mat
Added a basic gulpfile.js to the theme, expand/reduce at your leisure. It’s fairly basic and should be used as a jumping off point.
Hi, can I check if gulpfile.js supports ES6 ES2015 javascript? I think it will throw an error if there are ` characters in the Javascript string. Maybe the barebones gulpfile should support ES6?
@chenningg If you’re up for doing this that’d be great. Submit a pull request
Would love to help but I don’t really know Gulp and how Ghost uses it yet… might find some time to learn it over the coming weeks so I’ll see.
