- What’s your URL? This is the easiest way for others to debug your issue
hitchcock.dev - What version of Ghost are you using?
3.33 - What configuration?
Ubuntu 18.04 LTS
MySQL - What browser?
Chrom - What errors or information do you see in the console?
brennan@localhost:/var/www/ghost$ ghost run
Theghost runcommand is used by the configured Ghost process manager and for debugging. If you’re not running this to debug something, you should runghost startinstead.
- sudo node current/index.js
/var/www/ghost/versions/3.33.0/node_modules/knex-migrator/node_modules/knex/lib/client.js:55
throw new Error(knex: Required configuration option 'client' is missing.);
Error: knex: Required configuration option ‘client’ is missing.
at new Client (/var/www/ghost/versions/3.33.0/node_modules/knex-migrator/node_modules/knex/lib/client.js:55:11)
at Knex (/var/www/ghost/versions/3.33.0/node_modules/knex-migrator/node_modules/knex/lib/knex.js:53:28)
at Object.connect (/var/www/ghost/versions/3.33.0/node_modules/knex-migrator/lib/database.js:26:12)
at KnexMigrator.isDatabaseOK (/var/www/ghost/versions/3.33.0/node_modules/knex-migrator/lib/index.js:589:32)
at Object.module.exports.getState (/var/www/ghost/versions/3.33.0/core/server/data/db/migrator.js:13:25)
at isDatabaseInitialisationRequired (/var/www/ghost/versions/3.33.0/core/server/index.js:172:21)
at makeGhost (/var/www/ghost/versions/3.33.0/core/index.js:13:12)
at Object. (/var/www/ghost/versions/3.33.0/index.js:27:1)
at Module._compile (internal/modules/cjs/loader.js:778:30)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
at Module.load (internal/modules/cjs/loader.js:653:32)
at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
at Function.Module._load (internal/modules/cjs/loader.js:585:3)
at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
at startup (internal/bootstrap/node.js:283:19)
at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
Ghost LS says site is running, but not responded and refusing connections.
