Ghost error, showing mysql not installed
If you’re looking for help, please provide information about your environment. If you delete this template and don’t provide any information, your topic will be automatically closed. I tried multiple times, but the issue persists. I’ve provided the output for ghost doctor as well.
While trying tp update Ghost to 5.0, this is the error I’m facing
And
  • How was Ghost installed and configured? Using DO instance
  • What Node version, database, OS & browser are you using? Node - v16.15.0, mysql8, Ubuntu, v20.04.4 LTS
ℹ Downloading and updating Ghost [skipped]
Knex: run
$ npm install mysql --save
Cannot find module 'mysql'
Require stack:
- /var/www/ghost/versions/5.1.0/node_modules/knex/lib/dialects/mysql/index.js
- /var/www/ghost/versions/5.1.0/node_modules/knex/lib/dialects/index.js
- /var/www/ghost/versions/5.1.0/node_modules/knex/lib/knex-builder/internal/config-resolver.js
- /var/www/ghost/versions/5.1.0/node_modules/knex/lib/knex-builder/Knex.js
- /var/www/ghost/versions/5.1.0/node_modules/knex/lib/index.js
- /var/www/ghost/versions/5.1.0/node_modules/knex/knex.js
- /usr/lib/node_modules/ghost-cli/lib/tasks/major-update/data.js
- /usr/lib/node_modules/ghost-cli/lib/tasks/major-update/ui.js
- /usr/lib/node_modules/ghost-cli/lib/tasks/major-update/index.js
- /usr/lib/node_modules/ghost-cli/lib/commands/update.js
- /usr/lib/node_modules/ghost-cli/lib/bootstrap.js
- /usr/lib/node_modules/ghost-cli/bin/ghost
Error: Cannot find module 'mysql'
Require stack:
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
    at Function.Module._load (node:internal/modules/cjs/loader:778:27)
    at Module.require (node:internal/modules/cjs/loader:1005:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Client_MySQL._driver (/var/www/ghost/versions/5.1.0/node_modules/knex/lib/dialects/mysql/index.js:23:12)
    at Client_MySQL.initializeDriver (/var/www/ghost/versions/5.1.0/node_modules/knex/lib/client.js:190:26)
    at new Client (/var/www/ghost/versions/5.1.0/node_modules/knex/lib/client.js:75:12)
    at new Client_MySQL (/var/www/ghost/versions/5.1.0/node_modules/knex/lib/dialects/mysql/index.js:21:1)
    at knex (/var/www/ghost/versions/5.1.0/node_modules/knex/lib/knex-builder/Knex.js:16:28)
    at getData (/usr/lib/node_modules/ghost-cli/lib/tasks/major-update/data.js:22:24)
    at Task.ui [as task] (/usr/lib/node_modules/ghost-cli/lib/tasks/major-update/ui.js:35:48)
    at /usr/lib/node_modules/ghost-cli/node_modules/listr/lib/task.js:167:30
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
✖ Updating to a major version
An error occurred.
Message: 'Knex: run
Require stack:
- /usr/lib/node_modules/ghost-cli/bin/ghost'
Info from logs
    OS: Ubuntu, v20.04.4 LTS
    Node Version: v16.15.0
    Ghost Version: 4.48.0
    Ghost-CLI Version: 1.19.2
    Environment: production
    Command: 'ghost update'
An error occurred.
Message: 'Knex: run
Require stack:
Stack: Error: Knex: run
Require stack:
    at Client_MySQL.initializeDriver (/var/www/ghost/versions/5.1.0/node_modules/knex/lib/client.js:194:13)
Ghost Doctor
✔ Checking system Node.js version - found v16.15.0
✔ Checking logged in user
+ sudo systemctl is-active ghost_healthvery-com
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v16.15.0
In the version folder, npm install mysql --force solved it.
It won’t install otherwise due to dependencies issue.
@haikukoten
I have the same problem. Have you solved it by using this command in ghost installation folder?
problem solved by updating Ghost CLI
Can confirm, you should upgrade your ghost-cli and retry first before attempting a force install.
# On a production server using a non-root user:
sudo npm install -g ghost-cli@latest
