Facing issue while installing ghost from digital ocean droplet
  • sudo systemctl enable ghost_camunda-hub-com --quiet
:heavy_check_mark: Starting Ghost
One or more errors occurred.
  1. ProcessError
[Mon Mar 20 00:01:41 UTC 2023] Pending, The CA is processing your order, please just wait. (1/30)
[Mon Mar 20 00:01:43 UTC 2023] Pending, The CA is processing your order, please just wait. (2/30)
[Mon Mar 20 00:01:45 UTC 2023] Pending, The CA is processing your order, please just wait. (3/30)
[Mon Mar 20 00:01:48 UTC 2023] Pending, The CA is processing your order, please just wait. (4/30)
[Mon Mar 20 00:01:50 UTC 2023] Pending, The CA is processing your order, please just wait. (5/30)
Exit code: 1
OS: Ubuntu, v22.04.1 LTS
Node Version: v16.17.0
Ghost Version: 5.39.0
Ghost-CLI Version: 1.24.0
Environment: production
Command: ‘ghost install --auto --db=mysql --dbhost=localhost --dbport=3306 --dbname=ghost_production --dbuser=root --dbpass=xxxxxxxxxxxxx–dir=/var/www/ghost --start’
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2023-03-20T00_02_19_727Z.log
For any further commands, please switch to the ghost-mgr user to manage Ghost.
sudo -i -u ghost-mgr
Please explain the process that you had followed to install Ghost.
i used ghost template from digital ocean. the moment you login it starts installing ghost and at the end this error comes up.
note: it did ask for blog url and ssl email i have provided during the installation
I had a similar problem. It turned out that it wouldn’t install on a 1GB RAM droplet. I upgraded to 2GB and it installed flawlessly.
