Ghost is not installing on digital ocean
I have tried to install ghost using droplet on Digital Ocean. I got an error. But I am not getting the solution.
Configuring DigitalOcean 1-Click Ghost installation.
Please wait a minute while your 1-Click is configured.
Once complete, you are encouraged to run mysql_secure_installation to ready
your server for production. Passwords have been saved to:
    root/.digitalocean_password
Ensuring Ghost-CLI is up-to-date...
+ sudo npm i -g ghost-cli@latest
[..................] \ fetchMetadata: sill resolveWithNewModule yarn@1.22.10 checking installable status        [..................] | fetchMetadata: sill resolveWithNewModule yarn@1.22.10 checking installable status                                                  [..................] | fetchMetadata: sill resolveWithNewModule color-convert@2.0.1 checking installable status
/usr/bin/ghost -> /usr/lib/node_modules/ghost-cli/bin/ghost
+ ghost-cli@1.15.3
added 26 packages from 16 contributors, removed 17 packages, updated 51 packages and moved 6 packages in 37.425s
Ghost will prompt you for two details:
1. Your domain
 - Add an A Record -> 161.35.122.128 & ensure the DNS has fully propagated
 - Or alternatively enter http://161.35.122.128
2. Your email address (only used for SSL)
Press enter when you are ready to get started!
+ sudo chown -R ghost-mgr:ghost-mgr /home/ghost-mgr/.config
✔ Checking logged in user
✔ Checking free space
✔ Setting up install directory
✔ Downloading and installing Ghost v3.40.5
✔ Finishing install process
? Enter your blog URL: https://kaminskiplus.de
✔ Configuring Ghost
✔ Setting up instance
+ sudo useradd --system --user-group ghost
+ sudo chown -R ghost:ghost /var/www/ghost/content
✔ Setting up "ghost" system user
ℹ Setting up "ghost" mysql user [skipped]
+ sudo mv /tmp/kaminskiplus-de/kaminskiplus.de.conf /etc/nginx/sites-available/kaminskiplus.de.conf
+ sudo ln -sf /etc/nginx/sites-available/kaminskiplus.de.conf /etc/nginx/sites-enabled/kaminskiplus.de.conf
+ sudo nginx -s reload
✔ Setting up Nginx
? Enter your email (For SSL Certificate) enamul.iu91@gmail.com
+ sudo mkdir -p /etc/letsencrypt
+ sudo ./acme.sh --install --home /etc/letsencrypt
+ sudo /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --domain kaminskiplus.de --webroot /var/www/ghost/system/nginx-root --reloadcmd "nginx -s reload" --accountemail enamul.iu91@gmail.com
✖ Setting up SSL
+ sudo mv /tmp/kaminskiplus-de/ghost_kaminskiplus-de.service /lib/systemd/system/ghost_kaminskiplus-de.service
+ sudo systemctl daemon-reload
✔ Setting up Systemd
+ sudo systemctl is-active ghost_kaminskiplus-de
+ sudo systemctl start ghost_kaminskiplus-de
+ sudo systemctl is-enabled ghost_kaminskiplus-de
+ sudo systemctl enable ghost_kaminskiplus-de --quiet
✔ Starting Ghost
One or more errors occurred.
1) ProcessError
Message: Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#'  /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --domain kaminskiplus.de --webroot /var/www/ghost/system/nginx-root --reloadcmd "nginx -s reload" --accountemail enamul.iu91@gmail.com
[Sat Jan 16 20:45:31 UTC 2021] kaminskiplus.de:Verify error:Invalid response from https://kaminskiplus.de/.well-known/acme-challenge/p5oeHuwNUYNrFpFj-IWilhHZlMH9QrFqofoJseTWWwk [2606:4700:3037::ac43:c239]:
[Sat Jan 16 20:45:31 UTC 2021] Please add '--debug' or '--log' to check more details.
[Sat Jan 16 20:45:31 UTC 2021] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[Sat Jan 16 20:45:24 UTC 2021] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Sat Jan 16 20:45:24 UTC 2021] Create account key ok.
[Sat Jan 16 20:45:24 UTC 2021] Registering account: https://acme-v02.api.letsencrypt.org/directory
[Sat Jan 16 20:45:25 UTC 2021] Registered
[Sat Jan 16 20:45:25 UTC 2021] ACCOUNT_THUMBPRINT='MeGBylrE1fTwmzBGd_FtEokW60E6HEXUypsc2jbIX_k'
[Sat Jan 16 20:45:25 UTC 2021] Creating domain key
[Sat Jan 16 20:45:26 UTC 2021] The domain key is here: /etc/letsencrypt/kaminskiplus.de/kaminskiplus.de.key
[Sat Jan 16 20:45:26 UTC 2021] Single domain='kaminskiplus.de'
[Sat Jan 16 20:45:26 UTC 2021] Getting domain auth token for each domain
[Sat Jan 16 20:45:27 UTC 2021] Getting webroot for domain='kaminskiplus.de'
[Sat Jan 16 20:45:27 UTC 2021] Verifying: kaminskiplus.de
Exit code: 1
    OS: Ubuntu, v18.04.4 LTS
    Node Version: v12.18.0
    Ghost Version: 3.40.5
    Ghost-CLI Version: 1.15.3
    Environment: production
    Command: 'ghost install --auto --db=mysql --dbhost=localhost --dbname=ghost_production --dbuser=ghost --dbpass=58486a38b83ea8e04686c81b60b9d04e094ddc0e1a8f452e --dir=/var/www/ghost --start'
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2021-01-16T20_45_58_995Z.log
You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
For any further commands, please switch to the ghost-mgr user to manage Ghost.
    sudo -i -u ghost-mgr
root@ghost-ubuntu-s-1vcpu-2gb-nyc1-01:~# ghost doctor
You can't run commands as the 'root' user.
Switch to your regular user, or create a new user with regular account privileges and use this user to run 'ghost doctor'.
For more information, see https://ghost.org/docs/install/ubuntu/#create-a-new-user-.
Looking for your help
Best Regards
Enamul Haque
Seems like it’s erroring out while setting up SSL…
& You are using Cloudflare dns
With cloud flare to issue LE ssl you need to make the A record & www record entry DNS only from proxied…
Hope it will help you
i just installed a new instance minutes ago, working out of the box here.
about the A and www records, try something like this:
Hi @inoryum and @matheus-rossi ,
I already created A record and CNAME record but it is not working.
Did I make any mistake?
Change the dns settings from proxied to dns only … That’s means the orange cloud icon make that gray …
Just to issue the LE certificate…
Thank you so much
Happy to help!
