I’ve just completed the build of my site and the one thing that is still vexing me is that for some reason the featured photos for the articles are cut off. They dont seem to be resized to the frames on the page. I’ve resized them in PS, but that hasn’t helped either. How do I fix that?
Ghost doesn’t manipulate image files in any way that would cut sections of them. It’s likely what you are seeing is how your theme’s styling works in which case fixing it would require editing the theme’s CSS.
Which theme are you using? If you share that perhaps someone can be of more direct help.
Yea, I just got a msg from the developer that gave me a code to put in the code injection box. that fixed it. I posted here first because I thought it had something to do with the 4.0 update interacting with the theme.
