[Fixed][problem after ghost update] Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#' systemctl is-active ghost_localhost
Status
Fixed. it work now
Website (currently down)
Problem
After ghost update, can’t start ghost.
Error Message
Message: Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#'  systemctl is-active ghost_localhost
failed
Exit code: 3
screenshot here:
ghost doctor
Github issue
I also create a Github issue with problem detail:
Server
Digital Ocean
1 GB Memory / 20 GB Disk / SGP1 - Ubuntu 16.04.3 x64
Need help
Thank you very much!
Somehow I fixed the problem myself.
sudo systemctl start ghost_localhost
and then
ghost start
Here is screenshot
not sure why ghost ls get
No installed ghost instances found
but now my blog 1c7.me working again
