I trying to add in image from Flickr using /image [url] but it ends up not displaying the image and as broken. I have tried different url’s to and different images from Flickr and nothing works. Any ideas?
For [url] are you putting the Flickr page’s URL or a direct URL to an image file? It needs to be a URL directly to an image file
That is correct I am using the URL to the page where the photo is.
I just emailed support about this, and then promptly resolved my own issue. You probably figured it out too!
I was trying to do →
/image IMG_6867 | emilie_OAK | Flickr
Then realized it is literally just the link itself.
The little tooltip is (IMO) a bit confusing bc it seems to indicate you need to write /image before the URL. But maybe I just don’t know how to read this stuff!
