Fundamental problem; can't see published post
First post here from newly joined creator.
Followed instructions to publish my first post, but a couple of days later its still not visible when I EXPLORE Ghost as a visitor.
Can’t find the reason in the user guide or forum and there is no obvious way of getting help from Ghost.
Thanks in advance for any steer as to where I have gone wrong and what change(s) I need to make.
If you’re on Ghost Pro (your domain is .ghost.io), you can always contact them at their support email: support@ghost.org
If you’re self-hosting, this community forum is a good place to ask!
I’m happy to try to help you figure this out, but I don’t understand your question. You said “Followed instructions to publish my first post, but a couple of days later its still not visible when I EXPLORE Ghost as a visitor.”
You mean when you go to your Ghost site’s url (without the /ghost), you don’t see the post? Or do you mean something else? (I think it’s the capitalized explore that’s confusing me, because there is a “Ghost Explore” that shows a selection of Ghost sites from around the web, but I wouldn’t expect a new site with one post to appear on it.)
Hi Cathy,
Thank you for your kind offer to help.
I realised that I hadn’t fully completed the process to add my site, and having done so it now seems to be discoverable to a visitor to Ghost.
Whilst I have some expertise in my subject matter which is highly quantitative, I’m very new to publishing so its been a bit of a learning curve.
