I’m running a self-hosted instance on a Digital Ocean droplet. Never had a problem with backups before, but now I’m getting a “504 Gateway Timeout” error when backing up via CLI. I was on 5.120.x prior to this. Tried backing up, restarting, backing up again. Was able to upgrade to the latest version of Ghost via ghost update, but still the same timeout error. The CLI logs don’t show any more than the output below, and the ghost instance logs show nothing. ghost doctor reports everything is normal.
Any thoughts?
ghost-mgr@ryansouthwickauthor-newsletter:/var/www/ghost$ ghost backup --verbose
https://careers.ghost.org
MySQL: running query > SELECT @@version AS version
+ sudo systemctl is-active ghost_newsletter-ryansouthwickauthor-com
+ sudo mkdir -p /var/www/ghost/backup
? Enter your Ghost administrator email address [redacted]
? Enter your Ghost administrator password [hidden]
✖ Backing up site
An error occurred.
Message: 'Response code 504 (Gateway Time-out)'
Stack: HTTPError: Response code 504 (Gateway Time-out)
at EventEmitter.<anonymous> (/usr/lib/node_modules/ghost-cli/node_modules/got/source/as-promise.js:74:19)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
Path: /ghost/api/admin/session/
OS: Ubuntu, v22.04.1 LTS
Node Version: v18.18.2
Ghost Version: 5.121.0
Ghost-CLI Version: 1.27.0
Environment: production
Command: 'ghost backup --verbose'
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2025-06-06T15_14_33_268Z.log
