I’m deploying my own gatsby-ghost project on Gatsby Cloud which tries to access some Ghost resources during the build phase. The build fails with the following error message:
23:40:34 PM: error Error processing images in node Ghost__Settings__1: failed to process https://static.ghost.org/v3.0.0/images/publication-cover.png HTTPError: Response code 403 (Forbidden)
If I build the same project locally on my machine everything works fine. You can also test that this resource can usually be accessed publication-cover.png.
I also checked that the same issue is present when building the site with Netlify. I suspect some DDos protection on static.ghost.org is kicking in here.
The error code 403 indicates, that https://static.ghost.org/ is blocking the request. Could you please inquire why https://static.ghost.org/ is blocking Gatsby Cloud and Netlify servers from downloading image assets and possibly lift the blockings?
Thanks a lot in advance!
