I working on a French website with gatsby-starter-ghost and I’m unable to use the readingTimeHelper because it come formatted in English.
Is there any way to only get the number of minutes (integer) and i will complete manually with the French text?
I’m open to any work around to make it work!
Assuming you’re using the @tryghost/helpers library, you can pass in the following options:
minute: "1 minute read",
minutes: "This post will take % minutes to read"
It work perfectly, thank you!
system
Closed
4
