Get JWT for signed-in Member
Hello Ghost community!
I am trying to follow the advice of @disaza and @egg as laid out here and here.
I am trying to get a JWT for a signed-in member by making a GET request to /members/ssr but I merely get a 404.
Is it still possible to get a JWT for a logged-in Member?
Thanks for your help,
Frei
I discovered the solution to the problem that I was having.
I realize now that I should have named this thread:
“Validating Member Authentication Cookie”.
What I discovered is that Member Authentication is managed via the ghost-members-ssr cookie, that this cookie is signed by the Ghost express server and is scoped to the specific domain hosting the ghost server.
This credential *can be used to authenticate custom software, which one is writing in order to integrate the Ghost CMS into a larger system.
However, the Ghost source code needs to be slightly adjusted --the MembersSSR.js file needs to be manually included and customized, so that the domain of the members-ssr-cookie is set --this makes the cookie valid for all subdomains as well.
Besides that the custom software must have access to the theme_session_secret from the settings table of the Ghost MySQL database. This key needs to be set on custom server to validate signed cookies against.
Now I’m trying to figure out how to use the admin_session_secret to validate Admin cookie/token.
