Get latest posts inside author looping
I need to create a author list which will hold authors info as well as his/her latest 4 posts. My design will be look like this,
Here is my approch after searching google and digging in docs.
{{#get 'users' limit="all" include="count.posts,posts"}}
        {{#foreach users}}
            {{!-- user datas --}}
            {{name}} , {{bio}} // ... and so on
            {{!-- This user's posts --}}
            {{#foreach posts limit="3"}}
                <a href="{{ url }}"> {{ title }} </a>
            {{/foreach}}
        {{/foreach}}
{{/get}}
I’m getting user data perfectly but can’t get individual user’s posts by this,
{{/foreach}}
Please make me correct.
Thanks.
As per the documentation, when you get the users resource you can only include “count.posts” . Ghost Handlebars Themes - Building a custom Ghost theme - Docs
The User and Tag resources can be expanded to include the post count for each resource.
Include options for User and Tag : “count.posts”
You can try to nest another get helper request. Although as per the documentation ( Ghost Handlebars Themes - Building a custom Ghost theme - Docs )
  • {{#get}} helpers may not work correctly when nested
You can try this
{{#get "posts" filter="primary_author:{{name}}" limit="3"}}
    {{#foreach posts}}
      <li><a href="{{url}}">{{title}}</a></li>
    {{/foreach}}
{{/get}}
I have not tested this, not sure will it work or not, but you can try this approach.
Thanks for your helping approach, unfortunately this nested get helper is not working in my theme :’(
Here is the right way to do this:
{{#get "users" limit="all" include="count.posts"}}
	{{#foreach users}}
		{{#if count.posts}}
			<h3>{{name}}</h3>
			<ul>
			{{#get "posts" filter="primary_author:{{slug}}" limit="3"}}
				{{#foreach posts}}
				{{/foreach}}
			{{/get}}
			</ul>
		{{/if}}
  	{{/foreach}}
{{/get}}
First we fetch all the users. Then we parse them. We check if the user has any posts. If it doesn’t we don’t show it. Then we fetch 3 posts where the user is the primary author. That is it.
Thanks @HauntedThemes , it works :slight_smile:
