Hello,
Is it possible to using rest-api in posts? I have API and want to call it for some information which will be added to post.
Everything is possible if you use the Fetch API from JavaScript ![]()
fetch('http://example.com/movies.json')
.then(response => response.json())
.then(data => console.log(data));
