the 404 is still here!
unlink /etc/nginx/sites-enabled/default
nginx -s reload
nginx -s reload
the 404 is still here, it’s not gone
Try:
server {
listen 80;
listen [::]:80;
listen 443 ssl http2;
listen [::]:443 ssl http2;
{{ssl_certificate_key}}
{{ssl_certificate}}
server_name www.ghost.loglotdev.com;
return 301 https://ghost.loglotdev.com$request_uri;
server {
listen 80;
listen [::]:80;
{{ssl_certificate}}
server_name ghost.loglotdev.com www1.ghost.loglotdev.com;
{{root}}
{{nginx_access_log}}
{{nginx_error_log}}
if ($scheme != "https") {
rewrite ^ https://$host$uri permanent;
location ~ /.well-known {
auth_basic off;
allow all;
{{settings}}
add_header Cache-Control no-transform;
index index.html;
location / {
proxy_pass {{reverse_proxy_url}};
proxy_http_version 1.1;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_pass_request_headers on;
proxy_max_temp_file_size 0;
proxy_connect_timeout 900;
proxy_send_timeout 900;
proxy_read_timeout 900;
proxy_buffer_size 128k;
proxy_buffers 4 256k;
proxy_busy_buffers_size 256k;
proxy_temp_file_write_size 256k;
But remember that You need to change it for your own use.
alright, the issue was something none of you would have been able to fix, sorry. but it’s working for me now
