My Ghost Theme build using Bootstrap4
I am using Ghost Markdown + Bootstrap CSS Styling Functions
Recent Gscan Recommended to add .kg-width-wide & .kg-width-full CSS Class
it’s compulsory to add this two classes or optional?
@mskian the classes are required for it to be a fully valid Ghost 2.0 theme because they are needed for the image sizes editor functionality to work. You can read more about them in the docs:
it require only for images? right
At the moment, yes.
We have discussed adding width options to image/video embeds sometime in the future which is why the classes are generically named and applied to the <figure> element rather than the <img> element. However for now the width options are only used for image cards.
Thanks got it
Mostly I use Markdown Option only
anyways I refer Casper theme CSS
If you want to use the latest Keonig features with Bootstrap, give Paper a try.
