Ghost CMS Docker Error Code -97
Hi together,
I try to start my Ghost CMS in a docker. This is my docker-compose.yml
services:
ghost-cms:
image: ghost:5-alpine
restart: always
depends_on:
  - ghost-db
healthcheck:
  test: [ "CMD-SHELL", "nc -z localhost 2368 || exit 1" ]
  interval: 10s
  timeout: 5s
  retries: 10
ports:
  - 2368:2368
environment:
  database__client: mysql
  database__connection__host: ghost-db
  database__connection__user: ghost
  database__connection__password: ghostdbpass
  database__connection__database: ghostdb
volumes:
  - ./dockers/cms/content:/var/lib/ghost/content
ghost-db:
image: mysql:8.0
restart: always
healthcheck:
  test: [ "CMD", "mysqladmin", "ping", "-h", "localhost" ]
  interval: 10s
  timeout: 5s
  retries: 5
environment:
  MYSQL_ROOT_PASSWORD: test
  MYSQL_USER: ghost
  MYSQL_PASSWORD: ghostdbpass
  MYSQL_DATABASE: ghostdb
volumes:
  - ./dockers/cms/mysql:/var/lib/mysql
The database is up, but the ghost-cms shows the following logs and I don’t find any infos about that Code.
[2025-01-10 14:43:32] WARN Ghost is shutting down
[2025-01-10 14:43:32] WARN Ghost has shut down
[2025-01-10 14:43:32] WARN Your site is now offline
[2025-01-10 14:43:32] WARN Ghost was running for a few seconds
[2025-01-10 14:44:32] ERROR (Code: -97)
(Code: -97)
“There was an error starting your server.”
“Please use the error code above to search for a solution.”
Error ID:
6793c6d0-cf61-11ef-b518-1b7f5ba98042
InternalServerError: (Code: -97)
at Server. (/var/lib/ghost/versions/5.105.0/core/server/GhostServer.js:96:34)
at Server.emit (node:events:517:28)
at emitErrorNT (node:net:1844:8)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
I just found out, when I try to run the command from the hub.docker.com page:
docker run -d --name some-ghost -e NODE_ENV=development ghost:latest
I receive the same error, so it should be a local problem (on a remote server it works). But I don’t know what it can be…
Any Ideas?
I think the log you posted is maybe the end of a set of errors - can you grab the earlier errors, from when Ghost tried to start? There may be something there.
I have now spent the whole day looking for a solution to the problem. I had problems with my ipv6 the last days, so in my /etc/default/grub I had the entry
GRUB_CMDLINE_LINUX_DEFAULT="ipv6.disable=1 quiet splash”
After I changed this back to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash”
and performed an update-grub, the Ghost CMS Docker runs again as usual. Absolutely crazy.
If anyone has the same problem, maybe this will help :)
Thank you very much!
Ahha! Glad you fixed it. ‘localhost’ uses ipv6 by default in some setups… I’d guess you had something listening on ipv6 and something not able to use it…
