I am using the Ghost docker on Unraid, this happens with either “official” version. I am also using Nginx Reverse Proxy and Cloudflare.
When “url” variable is set to https://url.com and there is no custom Nginx config, I end up getting “too many redirects” in browser. If I go into docker and change the “url” to http, then I am able to get in using my custom domain but cannot see the preview images.
Then, I changed my Nginx config to:
location / {
proxy_set_header HOST $http_host;
proxy_set_header X-NginX-Proxy true;
proxy_set_header X-Forwarded-Proto https;
proxy_pass http://localhost:2368;
proxy_redirect off;
Now, I am able to use https normally and see previews in the admin dashboard but the previews and website now look like this:
I have tried:
- Deleting all appdata, fresh installing
- Creating new databases/using different ones
- Using different domain names
- Using different docker containers
I feel like I’m almost there, thank you for your help ahead of time.
Check your browser’s console for errors. I’m guessing this is perhaps a mixed http/https error? If so, check your config file for an http vs https discrepancy in the name of the server.
Error with Permissions-Policy header: Unrecognized feature: 'attribution-reporting'.
Error with Permissions-Policy header: Unrecognized feature: 'run-ad-auction'.
Error with Permissions-Policy header: Origin trial controlled feature not enabled: 'private-state-token-redemption'.
Error with Permissions-Policy header: Origin trial controlled feature not enabled: 'private-state-token-issuance'.
Error with Permissions-Policy header: Origin trial controlled feature not enabled: 'join-ad-interest-group'.
Error with Permissions-Policy header: Unrecognized feature: 'browsing-topics'.
blog.thelqh.com/:167
GET https://url.com/public/cards.min.css?v=51d40c92db net::ERR_TOO_MANY_REDIRECTS
blog.thelqh.com/:9
GET https://url.com/assets/built/screen.css?v=51d40c92db net::ERR_TOO_MANY_REDIRECTS
blog.thelqh.com/:10
GET https://url.com/assets/built/source.js?v=51d40c92db net::ERR_TOO_MANY_REDIRECTS
blog.thelqh.com/:168
GET https://url.com/public/member-attribution.min.js?v=51d40c92db net::ERR_TOO_MANY_REDIRECTS
blog.thelqh.com/:166
GET https://url/public/cards.min.js?v=51d40c92db net::ERR_TOO_MANY_REDIRECTS
blog.thelqh.com/:1 Error handling response: TypeError: Cannot set properties of null (setting 'textContent')
at chrome-extension://mobpimjmmonkghndllikpdgpapkfckje/popup.js:19:32
favicon.ico:1
GET https://url/favicon.ico net::ERR_TOO_MANY_REDIRECTS
I see there are errors happening in the background even though the site loads. If I go into Nginx and use
instead of https, it gives me ERR_TOO_MANY_REDIRECTS
I have it set to https in config and Nginx, should I look somewhere else? Thank you!
I think you’re going to need to post your config.production.json (minus secrets) and relevant nginx files to get help. :)
I’m /guessing/ your have your ghost url set incorrectly (or haven’t restarted since you changed it).
